Results 1 to 6 of 6
Thread: low Beam not working
    Senior Member andrewforbes's Avatar
    May 2013
    My low beam isn't working in my ef xr8, however they work when turning on high beam. Tried changing switch, no good. I'd like to change low beam relay but I don't know where it is, so could someone please tell me where it's located or if you have any idea as to the problem please post your thoughts
    a.k.a. T3man MisterAU's Avatar
    Batemans Bay, New South Wales, Australia
    The problem is most likely in the column multiswitch (commonly called indicator).
    Australian Muscle Car ... "It is a sensational high performance vehicle; a beautifully engineered and immensely capable four door Grand Tourer or 'GT' in the truest sense of that tradition."
    No prize for guessing what car they were referring to ... OWN THE ROAD ...
    May 2013
    So would that require replacement or is it possible to repair
    May 2013
    So u don't think it would the low beam relay
    Validated User VZTRT's Avatar
    May 2012
    If the low beam is working when you hit the high beam then more then likely multiswitch.
    You should be able to test relays by hearing and feeling them click.
    May 2013
    Thanks guys I'll look at getting a new one
