Page 12 of 14 FirstFirst ... 21011121314 LastLast
Results 111 to 120 of 132
Thread: Camping
  1. #111
    Correct RW, Polys are pretty good imo.....
    You left some air in them didn't you whilst not in use/towing right ?
    Right thing for Rob to fit one day.
  2. #112
    Yeah. In fact, I think they're still pumped up
  3. #113
    hehe, min 10lb mate when not laden.
  4. The Following User Says Thank You to FTe217 For This Useful Post:
    Road_Warrior (15th June 2017)
  5. #114
    Don't forget shocks are not load carriers, so even by fitting a firmer shock the ride height is the same with or without load.
    Run a stiffer/firmer shock unladen will ride harsh/er,
    Yeah ok, I thought a stiffer shock may help reduce the squat under load but obviously not. I don't really want to alter too much given 99% of the time it won't be towing. I think for the time being it will be fine as is but I wouldn't want it to be much lower.
  6. #115
    Dave, does your van run a hand pump water tap over the sink or have you got a 12v pump?
  7. #116
    Quote Originally Posted by prydey View Post
    It had one of those stupid plastic hand pumps but I installed a 12v one before Easter. Wasn't a hard job, just fiddly. You need to be confident with auto electrics though if you're thinking of doing it yourself.
  8. The Following User Says Thank You to Road_Warrior For This Useful Post:
    prydey (15th June 2017)
  9. #117
    Quote Originally Posted by Road_Warrior View Post
    do you run solar power to keep your battery topped up, or is there enough juice in a 100ah battery to run lights and a water pump for a few days?
  10. #118
    No solar. I've never run out of power on that battery. But, lights are turned off when they arent needed or when we're not in the van, the tap is only used when you need to fill the sink or kettle or whatever, and I never run the fridge off it. That Dometic 3 way (I see yours is the same model as mine) will flatten it within a day no problem.
    I plug the van in to the house for about 24 hours before going away which tops it up, and when on the move it is plugged into the car in any case so it is always full before use.
  11. The Following User Says Thank You to Road_Warrior For This Useful Post:
  12. #119
    Thanks. Good to know the battery should cope ok for short stays.
    As for the fridge, it will likely never run on 12v. Like you, the normal procedure for most people is to plug the van in to the house 24-48 hours before leaving to top up the battery and get the fridge cold.
    No Anderson's on the van yet and I only had 1 put on the car which I will eventually run the fridge off with a switch to turn off when car isn't running. I figured if the battery was full when leaving it won't need charging while driving.
    Thanks for the help. All new to me, esp knowing how many days you can get out of the battery etc. Will eventually add solar.
  13. #120
    No problem at all, I guess the only way you're going to find the limits of your battery is through trial and error, but if its in good shape I see no reason it can't last for 3-odd days. Eventually I want to add solar as well but most likely a portable job that plugs into the existing Anderson plug.
