Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: FG X XR8 Wheel Alignment
    Just Arrived
    Aug 2014
    ok ta, my original camber was close to -1deg both sides. this saw the inside scrub out big time on the OEM tyres. mind you got 36k out them but they were stuffed.
    Currently set at -0.25deg both sides, just gotta get the toe correct.
  2. The Following User Says Thank You to RedM For This Useful Post:
    FTe217 (1st February 2018)
  3. #12
    Member
    Feb 2016
    Auckland
    I’ve forgotten the centring procedure, but have read it on a Ford forum for modern Falcons before. A standard thing to do, just a case of turning a couple of rods the same number of turns on both sides of the car and tightening them up again. When I’ve had a misaligned steering wheel in the past ( misaligned from a previous alignment, it’s typically been fixed at the next one with or without my asking.
    Sounds bizarre to tell you a correct wheel alignment only gives you the option to have a crooked steering wheel. Do you think the guy was just being difficult? Annoyed over something perhaps?
    It’s normal for the XR8s to wear out the insides first. It’s not Dunlop dependent, and Sprint suspension is very different ( as well covered in this forum).
    There is plenty of leeway to align to owners taste or driving style, either for tyre wear or for performance.
  4. The Following User Says Thank You to imike1 For This Useful Post:
  5. #13
    Just Arrived
    Aug 2014
    No he's a good mechanic and has done work for me in the past. It does sound strange that aligned to spec sees the wheel off centre.
    I'll talk to him re the info you've mentioned.
  6. #14
    Mr Aftermarket :) FTe217's Avatar
    Aligned to spec is a given, doesn't mean that your wheel is aligned straight mind you.
    This has been the norm for as long as I have known, hence after test drive if wheel not straight they can centre the wheel without effecting the alignment done in the first place.
  7. The Following 2 Users Say Thank You to FTe217 For This Useful Post:
    13726548 (1st February 2018),imike1 (5th February 2018)
  8. #15
    Just Arrived
    Aug 2014
    So the only adjustment is via the tie rods, if you centre the steering wheel using the tie rods again isn't it going to affect the toe?
  9. #16
    Senior Member 13726548's Avatar
    Jun 2015
    Gold Coast
    Because you are just sliding it on the rack...
    I set mine at home according to tyre wear only, always have.
  10. #17
    RedM, has it been corrected ?
  11. #18
    Just Arrived
    Aug 2014
    Yes, -0.5mm both sides, total toe -1mm. Only took it or a short drive yesterday and wheel is centre with no noticeable pull. Heading out on the WE for a longer spin, so we'll see how it goes then.
  12. The Following User Says Thank You to RedM For This Useful Post:
    FTe217 (9th February 2018)
