Busted power steering pump - fluid
Hey guys, mysteriously my power steering pump has shit itself on my EL Fairmont Ghia, after sitting there for about a month or two with the occasional drive around the block, originally it leaked out the rear high pressure hose and toasted an alternator, so I replaced the hose and the alternator, and now its leaking from the front into the new alternator, GRRR!
Its also leaked onto one of the cooling system hoses and it has swelled up.
I'm going to replace the pump with a reco unit and I know EL/AU suggests this Valvoline power steering fluid, which I do indeed have here, but would it be worth running fully synthetic ATF like Castrol Transmax Z in the power steering system instead with the new pump?
I'm going to use it in my T5 when it goes in so I will have some spare left over.
