After the success of replacing the header tank and radiator switch, it now appears like the ignition switch inn the EF is cactus. I can still turn it to start the car, but when you turn it off, it goes all the way back to off, do not pass Accessories, Remove key...
What is the easiest way off replacing the ignition barrel? I'd prefer to not have to drill any holes, and reading online, just changing the barrel is quite easy, turn the key to accessories, push in a tab, and out she comes.
Has as anybody done this, and is this the best way of fixing the EF's latest problem?
