Our XE
A bit of detail:
Body
Ford Falcon XE 1983
6 point aluminium roll cage
Autotecnica Race Seat
Autotecnica 6 point race harness.
Power steering oil cooler
70 litre fuel cell
Painted by Cundari Bros Panels Shepparton
Cooling System
4 core radiator
8 blade plastic mechanical fan
Hi-flow racing thermostat
Engine (bottom end)
351 Cleveland with original bore
Flat top pistons
Balanced crankshaft
Balanced harmonic balancer
High Performance Cam
High flow oil pump
ASR 7.5 litre sump
Double timing chain
Oil cooler
Engine (top end)
2V heads with 20 thou off
Heavy duty valve springs
Standard rockers
Anti pump up lifters
GT valves
Chrome Molloy pushrods
Weiand X-CELerator Inlet Manifold
Holley 650 Double Pumper 4 barrel
Holley Electric Fuel pump
Holley Fuel Regulator
Exhaust system
Pacemaker extractors (4:1)
2.5 inch exhaust by Midland Mufflers Shepparton
Electrical / Wiring
MSD Coil
MSD Distributor
MSD Ignition System
MSD 8 mm plug leads
Clutch and Flywheel
Exedy 11” Heavy Duty clutch
Balanced and shaved fly-wheel
Gear box
BorgWarner 4 speed V8 gearbox
Diff
3:23 diff (or 2:92 - depending on which track)
Mini spool
28 spline axes
EL Falcon backing plate
Brakes
4 wheel disc brakes
DBA Series 4000 BA front rotors
AUII callipers
Standard DBA rear rotors
DOT 4 Racing brake fluid
Suspension
Pedders Sports Ryder Shockers
Pedders 800 pound front springs
Pedders custom 30 mm sway bars
Upper control arms lowered by 12mm
Lower control arms extended by 25mm
3.5 degrees negative camber
.5mm toe out
All suspension work donated by Pedders Bendigo
Not our video, but I love it, my son is driving, you will need to move to about the 4:50 mark and then listen to the XE - :D
https://www.youtube.com/watch?v=oQV0Ztke95g
Great work, Trevor, well done. Car looks great.
Quote:
Originally Posted by
Trevor
Thanks for sharing this I thoroughly enjoyed it. Not too many Clevos sound this good.
We are not terribly happy with the sound, we think it can be better, it is a balance on power and sound
These days are always very unpredictable, most of the cars are road goers and the drivers novices, it is a come and try day, $35 gets you onto the track, virtually unsupervised for the day. Winton do have vehicles placed around the track to monitor things and idiots are removed from the track pretty quick.
Awesome Trevor. Great to see another track car on the forums :)
very nice Trevor. Bet you had as much fun building it as you do racing it
