Today was my third try with this latest set up and forth overall to see if this stuff is worth doing.
I now think some of my very first snow experience might have been unfavourable due to the pressure device and nozzle being used. With that in mind I would like to try Bowdens again to see if I get a different result.
https://scontent.fmel1-1.fna.fbcdn.n...e4&oe=59CD3697
https://scontent.fmel1-1.fna.fbcdn.n...90&oe=59D08E5E
The mix used here still isn't right. I think I can reduce it a bit but a 1 litre mixing bottle is on track to do 3.25 cars with 400 ml of solution. I think somewhere around the 100ml per car wash sounds reasonable which at between $50-60 for 5 litres isn't too bad. If it works.
I have to say after today I have changed my mind.
This particular brand doesn't stay on the car like others, to the point there is debate as to if its really snow. You can see in the photos that there is plenty on the ground and these photos were taken a few minutes after the application.
There is no doubt about the softening of dirt and in the case today, even tar.
The wax situation right now isn't good on this car, so I expect even better performance once decent protection goes on.
