Double down. F.E.N.A test the auto GT Mustang
Having been provided with the opportunity to test the auto version of the GT Mustang, I thought it might be a good opportunity to revisit some of the more controversial aspects of our original review.
Some said we were too soft, too kind, owners said we bashed the car and it came from a position of hate or Falcon denial.
Collectively we never pulled punches and this review will be no different.
First of all, simpletons the world over need to realise that when reading a review of a product you already own, that review isn't speaking to you.
You have made your decision based on whatever. You own the car, what's said in any review has no bearing or influence whatsoever on a purchase you have already made. If this applies to you, take a seat and a double dose of chill pills.
As a biased media outlet only wishing well of Ford and for Ford products, where possible, negativity will be placed in the most detailed of context.
If for example I speak about cup holders obstructing gear shifts, if you have your car sitting in the shed for the weekend, clearly what you should be thinking is it's less of an issue for part time use as it would be for daily use.
I have a daily use mindset with this car.
That's the perfect leg on which to kick off, because with determination I have lined up just about everyone and videoed the process of review.
If your name is Paul, you won't be happy.
If your name is Bob, you won't be happy.
The short version.
Quality.
On film you will see me check the car over. You will see me measure paint thickness for quality and consitancy and you will see the process of checking fittment and gap consistency.
We repeat for the inside and demonstrate some awkwardness that was mentioned in our original review.
Performance
This cars engine wasn't as strong as Fords car. It also didn't have the kms on it.
Noise
On my roads the car also wasn't as quiet as we experienced on mainland roads.
Auto
Solves a lot of liveability issues. The tune can cause hunting at slow speeds. Town limits have it wanting to use a higher gear than you should be using. Fuel conservation is playing a part here. It is best not to use drive and that might be something some auto owners might not like.
Manual response was ok.
Brakes
Identical. Sensational.
Seats
Caradvice are moronic.
Engine sound. More of an issue in the auto. The fun aspect of the manual was such that it was easier to bring that sound track up. Again don't use drive.
Handling.
You can't hide in Tasmania. Back to back to back targa stages saw cars pulling off the road in front of me. It will understeer, it will oversteer but my option hasn't changed. It's a very good balance between compliance and performance for the enthusiastic driver who has brains and a sense of self preservation.
For the heros among us, aftermarket you will go.
Supercharger
Not for me. Not in a car as a daily driver. It will uncover short comings in this car if you don't address the package. In my opinion that is.
Conclusion.
Hopefully the videos come out ok and I can use them this time. We aren't off to a good start with the PC not seeing the go pro so for the time being you get this.
Now is the time to be looking at this car.
There has been improvements in quality. My body works was consulted earlier in the week, they are seeing the same thing.
On top of that, you have choice. There are stock on the ground where you can inspect before you buy. Buying power has shifted back to the consumer.
Deals are there to be had but better still, there are demos to drive.
As good as it is to stand back and look over, it's best when driven.
It's another Ford that makes you want to drive it.
Pros
Excellent seating position
I have a steering setting that I like.
Engine that largely ignores what's claimed
Balanced chassis and suspension
Awesome brakes.
Cons
Some ergonomic challenges
No digital speedo but it does give you digital cruise set speed.
Lacking some tech features
Thank you Ian for going to the trouble and time to do this review. I am very much looking forward to your video series on this car, especially as s potential buyer. Given I am coming from the same perspective ( used as a daily ) this will be very relevant to my needs.
Sent from my iPhone using Tapatalk
