Hi Guys,
I have brought a kit of DRL's and installed them into my grill it's all installed apart from wringing it up.
Earth wire is installed it's a no brainer for that.
Red+ Wire - needs to connect to ACC.
Blue Wire - needs to connect to parker so the DRL's dimm.
White Wire - needs to connect to low beam headlights so the DRL's turn off.
This is so they work like factory.
Now it suggest's to use the engine bay fuse box so witch fuses in the fuse box are ACC, Parkers & low beam headlights.
The kit came with some Circuit Fuse Tap MINI Blade Fuse Holders for clean install.
I would prefer this method so I don't have to tap into wires.
I don't have the books and the fuse box covers have nothing ?
