EA rear calipers: brake lever handles not lined up
I have just noticed that the two brake lever handles on my EA- axled trike are not at the same angle. One points up from horizontal and the other has dropped. I rebuilt both sides and I am pretty sure I would have noticed if it was like this when I put them back on: the spring on that side is _extremely_ hard to get onto the two end points...much harder than the other side.
Do these levers gradually rotate as the pads wear? I know that the unit adjusts the pads by rotating a threaded segment inside another and that the handbrake is applied by rotating that fitting.
The side that is dropped has been binding from time to time and I am concerned that this may be happening as I travel (it actually stopped the trike while driving once, before I rebuilt them), causing severe wear on the pads on that side.
I know I can take out the pads and check, but as set up on the trike it's a bit fiddly and I figure it's worth asking.
Thanks for any help
Nick
