Covid 19 Fena advice thread.
A thread designed to cut through the bullshit and get to what you need to know.
The basics for you and your family.
Don't be fooled into thinking any one situation is worse than the other.
1 person doing the wrong thing is more dangerous than 500 doing the right thing.
Its not airbourne.
If it was the rate of infection would be way higher.
But it can travel in air if you cough or sneeze openly.
Obviously this has been true of the common flu since I was a boy. Its incredibly bad manners but one has to allow for it.
In this instance simply breathing doesn't transmit it. It has to be expelled.
How you cough or sneeze or spit will determine the consequences.
Avoid your hand. Even yawning with hand to mouth is an issue. Tissues, if you can get them, are gold standard if disposed of correctly.
Wash hands. Wash hands wash hands
Never put your hand to your face. Sounds easy, its not.
Studies show we touch our face up to 23 times an hour without realising.
This is the number 1 cause of transmission.
If you brush up against someone who used his elbow to cough into, if that surface touches your back say and you didn't know it, when you get undressed, your hand touches that and it's on you. What you do with your hand then determines the spread.
It can survive 9 hours maybe 12 hours on surfaces.
This means that high traffic touching surfaces are extreme risk.
The smaller the space the higher the risk.
Thats the very definition of a confined space.
When they aren't being sensationalist it appears its not as easy to pick up as you might be thinking provided hands stay away from mouth.
Using the F1 situation, 14 people were quarantined from the one confirmed team member. As of this writing no transferance has been credited to this individual directly.
A further Pirelli employee has been confirmed but no isolations for him have been required.
If you can work from home do so.
Avoid public transport and eliminate best you can touching surfaces such as ATM'S and touch screens if you can.
Public transport is really a huge no.
Its really is about controlling space around you.
Travel outside Australia is also a no right now.
Face to face for 20 minutes or in a room for 2 hours should be avoided.
Above all.
There is a clear age demographic that's impacted the most. Over 65 take extreme caution. If possible these people need to self isolate the most.
Don't worry or panic.
Stress has been proven to lower your immune system efficiency.
Replace these with awareness and diligence to control what you can.
