Sorry but I'm bored.
Torque = power x 9551/rpm.
It is a bugbear of mine that people compare horsepower and torque when in reality torque is but a result of the POWER at given revs.
So I can reword a statement and say a Windsor makes great horsepower at midrange rpm and very bad torque at high rpm. If someone reads that and quotes me as saying the Windsor has good horsepower and bad torque it would be wrong since they haven't mentioned the rpm that is relative in this equation...... in the same way traditionally people have been saying the Windsor makes good torque and bad power; they are also WRONG by not linking the amount of torque or power to revs.
A car does 400 km to a tank of fuel. Is that good or bad? Naturally you would then ask how many litres of fuel does this tank hold. You need more info to understand the full picture.
The Windsor is a "torquey" motor is what y'all should say. Meaning it has a power delivery whereby peak torque is reached earlier in the rpm range compared to other engines. For example the 185kW Windsor does not have more torque than a Gen 3 so which is "torquier"? The Windsor is, because it arrives at it's peak torque noticeably earlier than the 5.7 does. At the point where it makes it's peak torque it may or may not have more torque than the Gen 3, but let's assume it does. If it's making more torque at about 3000rpm that would automatically mean it's also making more power at those revs, therefore the 185kW Windsor is a more powerful engine than the 220kW Gen 3....... at 3000rpm.
That is but half the story.
If I got a 40kW, 8 pole motor and coupled it to 1000:1 industrial gearbox I would then be able to pull a train. I'm assuming 545,000Nm is enough to pull a train. So much torque but is that good for speed?????? NO!
If you want speed from your vehicle you need horsepower. Dick Johnson even said it once; they tried to maximise the torque from their engines and found that to be a waste of time so they went back to focusing on maximising horsepower in the last band of revs up to 7500rpm.
I do appreciate "torquey" motors for the street though.
