Originally Posted by
FTe217
I get quite baffled by the failures like the diff bush's.
Now many of us have been at You Yangs faciltiy and seen the number of test sections that is set up to put X new model through its paces, abused like mad in regards to pot hole simulation but worse, some of those gaps/holes divided by those metal ridges you'd think it would bust anything weak under car pretty quick, (as a Enthusiast owner you know you avoid as much as possible on the road ahead that would shatter your tyres/rims suspension plus avoid rattling your teeth might I add) then I'm sure they do launch after launch - bang into reverse hard and stomp on the accelerator again and again, probably not the way I'm quoting but you know what I mean, overall they give the new model extreme abuse right.
Didn't the blade diff bush's let go prematurely ? surely they did.
