Yes i followed that build as well. Mind blowing.
The ZF's need to be rebuild and input shafts upgraded if you are going to chase these big numbers..and use the car as spiritedly. Look after it,and drive it edging on the side of caution and the stock box may last a little longer but it is pretty easy to overwhelm an auto. From my experience you are best to accept that its more of case if 'when', not 'if' the box and other components will need strengthening. Don't like the sound of that? Then keep boost and engine mapping parameters in check.
