GTS has 740nm
No its just a general question as a benchmark experience.
Clearly you have tuned 335s and 310s. 700nm as a number is starting to get into rarified numbers as a driving experience especially for the money. To go buy those two cars as a base for modification is going to cost your more I would think.
This is a good question. I don't think it would be Rwkws. With factory background I don't think they would change the language to something people wouldn't normally hear.
I did wonder though if this number represents the use of overboost.
Ford cant claim such a number because there would be some occasion where it is under.
In this concept it doesn't have to be presented like that.
Any thing ford state in a FI engine will be the minimum it does. The fact is its probably less than 1% doesn't stop them from needing to promote that lowest value.
I doubt there is overboost attached to this but I guess there could be.
Its a good question to ask. I will note it with the others.
Just checked with Bernie and I was sort of right.
The numbers are the transient numbers which is what I was saying is a peak value.
So the engine is still using transient programming which is important to realise.
