26th February 2016, 08:19 AM
#1
Wiring 4-pin BA radiator fan assy to BF 3-pin connector
Hi there,
I am not a fully technical person and also not very familiar with the jargon so will try to explain in simple words:
My Falcon BF had an unpleasant meeting with small kangaroo and damaged the radiator, air condenser and fan assembly.
I have got all required parts but for some reason decided to buy BA double fan assembly as I thought it will be more effective for cooling.
The problem here is:
Original fan has got 3-pin connector while new fan assy has got 4 pin one.
out of 3 wires of the old fan I deducted:
1 black (from the battery)
2 reds (1st, 2nd fan speeds)
out of 4 wires I assume:
2 blacks (from the battery feed)
2 reds (engage 1 or 2 fans)
I am contemplating of forking 1 original black wire into 2 black ones and connect it as below:
1 black to 2 blacks
2 reds to 2 reds
Will there be an issue with fuses on using this custom wiring?
Any other thoughts, ideas are appreciated.
Thanks
Max
26th February 2016, 08:42 AM
#2
Pretty sure there is an extra relay for the second fan (thats controlled by the ECU btw).
If you don't have a schematic and aren't sure what your doing then get someone who does.
Tags for this Thread
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
