Want to do a front end swap with an fpv f6 bumper. Not sure what they style or bumper is called but this is it
Will have to get fog and headlights to suit the style which is fine but just wanted to make sure it would fit
Getting hold of a genuine one will be your problem. FoA will charge like a wounded bull.
BAII RTV A Farmers Rocket.
I cant see why it wouldnt bolt up with the parts that you have mentioned.
There might be some 'special' FPV parts for the undertray or different inner guards, but i would assume the mounting points would all be the same.
Big $ going genuine even if used, and yeah few restricted parts too. Been there done that. If you're not precious about going genuine you could likely get something at 1/4 the cost aftermarket in glass.
aren't the headlamps different on the FPV vs XR6/8..?
Yes teardrop vs flat bottom. Aftermarket skirt will support teardrop otherwise new genuine lights about $360 a piece.
Easier to find a 2nd hand from a wrecker and buy the lot complete with all the little brackets etc, which will otherwise drive you insane tyring to work it out
The problem with society today, is that nobody drinks from the skulls of their enemies anymore.
ausmac91 (20th May 2016),Bluestuff1 (20th May 2016)
