Ok guy’s, today was the 1’st day that I have used the cruise control on the Territory, and I noticed that it dropped fairly significantly while going up a slight long incline, I had it set at 113 and it dropped right down to 103 until it changed down a peg and cruised back up to 113, I thought that cruise held the speed with in a few k’s of the set limit, I didn’t expect it to drop 10 k and then kick it down a gear ?.
It also did it when I had it set on 103 and then once again on a hill, it dropped back slowly until 94 then changed gear and went back up.
My AU's cruise is nothing like this and changes gear and holds the set speed quite well, is this just a different function on the newer car’s, i.e. Territory or could there be something wrong with the cruise control ?.
