Page 76 of 79 FirstFirst ... 26667475767778 ... LastLast
Results 751 to 760 of 785
Thread: The XW
  1. #751
    What an absolute mole of a job this turned out to be! I'm almost done, I'll finish up (hopefully) in the morning. Getting that C4 out was a bastard, along with some muppet selling me the wrong flywheel bolts and the trans jack not working properly or at all sometimes. To their credit the owners fixed it ASAP. So much fiddly shit and stuffing around, at least it is out now:
    And the toploader in. This better be worth it! So all I've got left to do now is:
    -Fill the 'box with oil
    -jury-rig the speedo cable somehow so it doesn't hang down (auto and manual speedo cables are different lengths)
    -fit the manual pedals
    -tighten up the engine mounts
    -fill the clutch reservoir and bleed the system
    -do a skid
  2. The Following 2 Users Say Thank You to Road_Warrior For This Useful Post:
    4Vman (22nd July 2017),FTe217 (24th July 2017)
  3. #752
    Knowing my luck Murphy will throw a spanner in the works again, most likely with the pedals or oil will piss out from somewhere, but the hard work (and I mean hard) has been done. The 3/4 shift rod fouls on the side of the gearbox a bit so that is an issue going forward, the speedo cable will need to be addressed in due course. Plus I can see from being under the car for quite a bit this week it will need new uni joints. Here is the new assembly sans gearbox bolted up to the car. You can see the new shifter in its rightful spot too
  4. The Following 3 Users Say Thank You to Road_Warrior For This Useful Post:
    defective (21st July 2017),FTe217 (24th July 2017),Randel (22nd July 2017)
  5. #753
    You were right defective. Totally different animal with a toploader in it, holy shit it hammers now
  6. The Following 2 Users Say Thank You to Road_Warrior For This Useful Post:
    defective (23rd July 2017),FTe217 (24th July 2017)
  7. #754
    Quote Originally Posted by Road_Warrior View Post
    Well done.
    How was the skid?
  8. #755
    Quote Originally Posted by 4Vman View Post
    Well done.
    How was the skid?
    LOL I didnt do a skid but did have some brown pants moments when standing on it a 70km/h and the bastard wanted to skip sideways and the diff ratio is 2.75 too!!
    Still some things to address though. Clutch pedal rod is way too short. Gotta get a manual trans speedo cable, and the output shaft seal leaks quite a bit.
  9. The Following User Says Thank You to Road_Warrior For This Useful Post:
  10. #756
    Oh, and I have to buy a new reverse light loom because I accidentally sandwiched the trans safety switch loop wire between the gearbox and bellhousing and fucked it
  11. #757
  12. The Following User Says Thank You to Road_Warrior For This Useful Post:
  13. #758
    So in terms of the repro shifter, it is a great bit of gear, shifts very nicely with no vagueness (just like a bought one lol) and I'm glad I got it. However I am rating it 4 stars out of 5 because the 3/4 shift rod rubs against the side of the gearbox and a couple of the shift tabs didnt press cleanly onto the selector posts. For $700 plus freight it should be a 100% spot on fit.
  14. The Following 2 Users Say Thank You to Road_Warrior For This Useful Post:
    4Vman (23rd July 2017),FTe217 (24th July 2017)
  15. #759
    Right, I need to piss this automatic choke off, fucking shitful thing is annoying the shit out of me, you stop the engine for like 2 minutes and when you start it again it revs its tits off. Trouble is the ripoff shops over east charge up the arse for XW and XY choke knobs and cables
  16. #760
    Validated User Randel's Avatar
    Leeming, Perth
    Don't run a choke at all mate - it's not like you are using it as a daily in the middle of winter ?
  17. The Following User Says Thank You to Randel For This Useful Post:
    defective (30th July 2017)
