Hi Folks,
My EF is in a bit of a state at the moment. It has a persistent coolant leak, at the same time that the coolant level sensor has packed it in. I've been filling the header tank up fortnightly or so, or when the sensor told me it was time to fill up. Until Sunday, when the sensor gave up, the light came on the dash, and I pulled over very quickly, squeezed the top hose, saw how full the tank was, and kept going.
From what I've discovered, it looks to be leaking coolant from where the small hose from the thermostat housing meets the header tank.
Can the header tank be epoxyed, or am I up for a new one? Also, how much is a new Coolant Level Sensor?
The EF is also in need of some cosmetic work. Anyone know a good panel beater? I got knocked near the warehouse at work, and the lower bumper is held on with two screws and constant prayer...
