Ok guy’s, I have done a little bit of research of late about coolant, as my XW radiator has a leak that I need to get fixed and in the process I am going to flush and change the coolant, Now I have been reading about Nulon and on their website how they state the following for vehicles pre 1984,
NOT suitable where anti-freeze/anti-boil coolant is specified. Use Nulon Long Life Concentrated Coolant (LL) for anti-freeze/anti-boil protection.
Nulon Ultra Cool (R45) contains corrosion inhibitors and is designed to provide maximum heat transfer in cooling systems where anti-freeze/anti-boil (glycol) is not specified. Heat transfer in the cooling system is done predominantly by water which has an excellent heat transfer coefficient. Glycol has the ability to extend the operating temperature range of a coolant, however it has a higher heat transfer coefficient than that of water. This is the main reason why non-glycol based coolants transfer heat much more efficiently than glycol based coolants.
In motor sport applications, Nulon Ultra Cool (R45) is a suitable alternate to glycol based coolant. Glycol is very slippery and is difficult to remove from the race track surfaces, which poses risks to other drivers on the track.
The use of tap water is not recommended for automotive cooling systems. Chlorine is usually added to tap water in order to kill bacteria and make it safe for drinking. However chlorine is found to be corrosive in cooling systems. Tap water also contains minerals that can cause scaling when used in a cooling system. Use suitable demineralised water for use with R45.
Where a vehicle manufacturer particularly specifies the use of anti-freeze/anti-boil coolant with glycol it is essential to use it as some engines suffer from localised "hot spot" boiling and require a glycol coolant.
So what have people used in their older Falcons, I always thought to use a Glycol based product but after reading the above it is not preferred for older vehicles,
I have used Tectaloy Gold in the past but this time round I think I might try the Nulon R45 for my XW and then something with a Glycol based for the AU.
Also do I have to use a Green coolant for the AU ?,
